CEL after ZZP Intake Install
Old Mar 25, 2012 | 08:45 PM
JAXFL_SS's Avatar
I installed the ZZP intake yesterday. Initially, I didn't have any issues. However, now, I am getting a CEL and sporadic boost issues (or lack thereof). I stopped by Advance and had them scan it, something to do with the MAF.
In doing some reading on the board, I see where some people are having issues with the oil on the K&N causing problems with the MAF. Does anyone know is a dry filter like one from AEM will fit on and replace the K&N? I'm not tuned yet, but I don't this is an issue that tuning will resolve.
Any thoughts?
Old Mar 25, 2012 | 08:55 PM
ATLsilverSS's Avatar
first i would remove the maf and if it is contaminated with k&n oil you will see it and know that is the issue. if not then contact zzp as this is something that should have been worked out before the release of the intake
Old Mar 25, 2012 | 09:01 PM
Nok817's Avatar
This sucks. I was going to be ordering a ZZP Intake next week or so but not if it's going to be throwing the CEL on.
Old Mar 25, 2012 | 09:02 PM
JAXFL_SS's Avatar
Yeah, I am planning on pulling it out tomorrow after work. If that is the case, I'll give ZZP a call on Tuesday.
As far as I can tell, I am the first one to get it installed that hasn't been tuned. However, I don't know that I tune would remedy this issue. I guess that makes me the guinea pig here...
Old Mar 25, 2012 | 09:03 PM
08SSREDHHR's Avatar
I know on the cobalt SS/TC's they have to turn the K&N filter upside down or something so it dosn't throw a code. My buddy did it and Ive seen threads about it on css.net. I hope thats the problem, i was planning on getting one and dont plan till get tuned till i get everything or i wont put it on till i get tuned
Old Mar 25, 2012 | 09:06 PM
JAXFL_SS's Avatar
I'm not sure how you would turn this upside down. I'll keep y'all posted.
Old Mar 25, 2012 | 09:07 PM
08SSREDHHR's Avatar
Has something to do with the K&N logo on the filter. Ill find the thread and post a link
Old Mar 25, 2012 | 09:16 PM
08SSREDHHR's Avatar
http://www.cobaltss.net/forums/08-10...talled-274100/
IDK if this will help but its worth a shot.
Old Mar 25, 2012 | 09:39 PM
you have to "clock" the filter...the seam needs to be "clocked" at xxxx o'clock to minimize fuel trim differences
i didn't realize you are not tuned. with our cars...you need a tune for everything since it's a maf car. every change in air flow effects the way the ecu reacts
Old Mar 25, 2012 | 10:09 PM
JAXFL_SS's Avatar
Thanks for the link. I'll check that out. I had never heard of doing that.
