P Codes popping up
Old 07-26-2017, 03:12 PM
Zabalal's Avatar
P Codes popping up
Hey guys! I have three codes pop up on my check engine light, and was wondering if somethings connecting the three.
P0327: Knock sensor (showed this code 2 times)
P2187: Bank 1 too lean (showed this code 4 times)
P0106: MAP sensor (showed this one once)
The car is running perfectly. I'm having issues with the battery, and plan to replace it next paycheck. Just wondering if there is something that I'm missing. So you guys know, this car has been up north most of her life. Had an issue with the turbo, and just needed to replace some wiring that was rusted from salt. So I also surmise that a connection somewhere needs to be rewired. Thanks in advance for any tips!
Zabalal is offline
Old 07-26-2017, 03:41 PM
J W Davis's Avatar
Weak battery or high drain will cause many of these faults. I figure the new battery will clear things up.
J W Davis is offline
Old 07-26-2017, 03:43 PM
Agree, wait and see what happens with a new battery, it might clear them all up.
Well, technically, replacing the battery will clear the codes. I mean they may not come back.
RJ_RS_SS_350 is offline
Old 07-26-2017, 04:07 PM
Welcome to the site, weak battery , agreed. I see you have a 2009 SS
The voltage not getting to the sensor in the P0327
https://www.obd-codes.com/p0327
Same for the P0106, possibly caused by low voltage or loose ground
https://www.obd-codes.com/p0106
But the P2187 may be because of other issues, have a read here
https://www.obd-codes.com/p2187
So, check the harness at the MAP sensor, check the ground wires, replace the battery as you intended, then watch for the CEL to possibly light up again in a while
Oldblue is offline
Old 07-28-2017, 06:10 AM
Zabalal's Avatar
Thank you so much guys! I'll replace the battery first thing Tuesday, and give you guys an update!
Zabalal is offline
Old 04-27-2018, 10:05 AM
shugarescu's Avatar
P2187
Any update ...? Did the P2187 code cleared / re-appeared after you changed the battery ?
shugarescu is offline
Old 04-27-2018, 10:07 AM
Zabalal hasn't been back to the site since his last post, 7/28/2017.
firemangeorge is offline
Old 04-30-2018, 09:18 AM
A 2 poster!
Oldblue is offline
mightymouse
07-11-2008 09:10 PM
BILL C.
04-12-2008 02:33 PM
rewcolee1
03-30-2007 05:56 PM
pontfirebird73
07-17-2006 10:49 AM
slamed87lincoln
05-22-2006 06:41 AM
Quick Reply: P Codes popping up
