Code P2178
Old Jan 16, 2020 | 01:31 PM
  #31
dsomonster's Avatar
Going with F4 tape. I have a huge military contingent in my family and they ALL recommended I use F4 tape over anything I can buy over the counter at HD or Lowes.
I will let you know how that works out.
Old Jan 16, 2020 | 02:25 PM
  #33
Originally Posted by Cat Man HHR
OR you can buy something like this.
I just measured mine and the rubber flex is 2" long and a tube size of 2 1/2"
Cut the old piece off, use a new hose clamp on hard plastic tube and use your original one that went to the turbo.
https://www.ebay.com/itm/2-1-2-2-5-S...gAAOSwRuVbMQjx
If it is a hole in the middle of the flex, then the tape might work. If it's a chunk broken off the end of the tube, then there's nothing there to tape to. Cat Man's second idea would be the better fix.
Old Jan 16, 2020 | 03:12 PM
  #34
Cat Man HHR's Avatar
Randy I agree what you said before. Need to see pictures.
Other than that it's all speculation.
Old Jan 16, 2020 | 07:25 PM
  #35
dsomonster's Avatar
I will pull the duct and take pics this weekend for you all.
Old Jan 16, 2020 | 08:54 PM
  #36
Would a piece of silicone hose work to replace it? Like they use on big truck induction systems.
Old Jan 17, 2020 | 02:57 AM
  #37
Please see what I posted line #30. Thanks.
Old Jan 17, 2020 | 08:11 AM
  #38
You didn't actually say "silicone hose" and I didn't follow the link, sorry.
BTW, you can pretty easily bend hoses by heating them up wit a torch.
Old Jan 17, 2020 | 11:27 AM
  #39
dsomonster's Avatar
Cat Man, what is the interior diameter of our outlet duct that attaches to the turbo? I am not sure the duct will fit over this piece since the fit to the turbo is snug. The hose is 5mm thick and I don't think the duct has that kind of play.
What do you think?
Old Jan 17, 2020 | 11:29 AM
  #40
dsomonster's Avatar
Thanks Don!
I will give the F4 tape a shot and if that fails, I may just breakdown and get a new duct. Still thinking about cutting the duct like Cat Man said and using the silicone extension, but if that fails, I am screwed and would need a new duct anyway.
-Ron
