cylinder 1 misfire detected
well...while driving in second gear around 10-15 mph i punched it to merge. got a CEL and engine was cutting out/ sputtering. the code has gone away and reappeared. to make a long story short sometimes i have full power and everything is great and sometimes not so much...sputtering, not getting past like 4000rpm or so
bought a scanner and code revealed was P0301 cylinder 1 misfire detected. Now where do I start to look to fix it? i sent chevymgr a pm and am awaiting his response but any help is much appreciated
All you gotta do...( love that statement !) break the system down for troubleshooting..It takes spark and fuel to make fire, so either you have a ign problem or a fuel delievery problem.....spark? Maybe a bad coil on that cylinder, loose wire,bad ground etc..fuel? water, inj plug loose..dirty inj, sticky inj, etc etc. Since its only one cyl doing it, it eliminates the entire system as being at fault.
I have to agree with the above.Usually it is an ignition problem related to a bad coil,plug wire,or injector plug-in.Just use common sense and trace it one component at a time.Make sure your getting spark from the coil pack to the plug wire ,plug wire to the plug etc...Coil packs going bad are not uncommon and will act like an old distrubutor cap that has been cracked.
Fred
You can isolate it to the coil by swapping coils with another cylinder and seeing if the misfire follows the coil. All four coils are identical. Or swap the coil to one cylinder and the spark plug to another and see it follows either one.
