Engine overheating
Old Nov 10, 2012 | 08:41 AM
BeExcited 2's Avatar
Unhappy Engine overheating
I have a 2008 HHR SS with 130,000 plus miles! the temp will rise while at idle or in traffic. It will come back to normal or close to it at higher speeds. I have noticed that the cooling fan does not come on. I can supply 12 volts to the fan and it runs ,I took the module to the dealer to replace it and was told they are not stocked and have never sold one nor has any one else, He says they never fail. I looked up a wiring diagram online and it shows a relay which I can't locate in the fuse box in my HHR? The service dept says a temp sensor (ECT) or computer. I also can't find the temp sensor. I Need Help!!!!!
Old Nov 10, 2012 | 08:57 AM
1970judge's Avatar
Does the fan come on if you hit the air conditioning?
Old Nov 10, 2012 | 09:02 AM
NO i don't think so, but I will have to double check that. I will do that right now
Old Nov 10, 2012 | 09:31 AM
I ran the temp to 210 with the A/C on and the cooling fan did not come on
Old Nov 10, 2012 | 10:42 AM
foolmoon_design's Avatar
Bad fan module. Not uncommon
Old Nov 10, 2012 | 12:38 PM
I took the fan module to the dealer and was told they don't stock it, have never sold one and don't show it in inventory. The other dealer in town says they have only sold one. Both say it is not the fan module........Do I believe them?????
Old Nov 10, 2012 | 12:51 PM
Snoopy's Avatar
I guess the first question I would ask......
How did the parts desk guys (assuming, you did not say specifically) know it was not the fan module? Did they test it....or was it an assumption on their part, based on sales experience?
Old Nov 10, 2012 | 01:09 PM
Assumption on there part! i have just started addressing this problem on Thursday. Neither dealership stock that part.
Old Nov 10, 2012 | 02:03 PM
ChevyMgr's Avatar
Cooling fan always runs on an SS, just at different speeds. What temp is it going up to at stops?
Old Nov 11, 2012 | 12:29 AM
Tony_W's Avatar
Yep bad fan or module. Had mine replaced along with the radiator at 56,000 miles. Fan failed caused car to oh and crack the radiator.
