Engine Rattle During Acceleration
I have 2009 SS with 195K miles on the odometer. The timing chain and water pump chain (and all their pieces (oiler, guides, tensioner, etc)) were replaced at 185K miles by me. I purchased my parts from the OEM supplier, Cloyes. The cam/crank sprockets looked fine and therefore were not replaced. The engine runs fine and has no CEL. It's all stock.
Over the last month or two, I have started developing an unusual rattle during acceleration. I can produce the same rattle in the driveway setting still, by revving to about 2-3K RPM and it seems to be coming from timing chain area. I plan to remove the valve cover soon to inspect. But I would be shocked if it was a timing chain problem since I just did the whole shebang 10K miles ago. I know the end-of-life sign for the timing chain is cold startup rattle, which I don't seem to have. But has anyone experienced some type of rattle during acceleration? |
Ping? Try a higher grade gas 93 if you can find it.
Maybe, flex pipe. |
Serpentine belt tensioner ?
(Post 927991)
Originally Posted by donbrew
(Post 927990)
Maybe, flex pipe. |
I completely understand being a price shopper.
BUT, does saving a couple of bucks worth the risk of 'bad' fuel. .10 cents a gallon times 15 gallons = $1.50 Not too me. |
Originally Posted by Lonwane
(Post 927999)
Please check the flex pipe, whether or not you think it is out of the question.
Air cleaner bracket? |
(Post 928002)
I just realized this is an SS. Turbo bearings?
A mechanics stethoscope would be handy, they are cheap at Harbor Freight. |
