Front hub/bearing tolerances
Old Dec 19, 2017 | 02:33 PM
FrugalAudio's Avatar
Originally Posted by Oldblue
What is the part number for those rims? Or the rim size and offset?
I’m wondering how the left side hits but the right side didn’t.
Checked my old invoice from TireRack:
17x7.5 Sport Edition F7 Silver
The hubs were installed at separate times, the left one (the one that's hitting) later. Basically I had the right side done when I put the snows on, the left side done when I had the summer wheels put on. I can only guess that the second hub was defective, or built to sloppier tolerances, or somehow damaged in installation. I'd have a hell of a job proving that now though.
I put spacers on yesterday and got the snows back on. Driving fine for now. Thinking maybe I'll take another look at the hubs in the spring. I don't have a driveway, and my options for borrowed space to work on the car myself are limited.
Old Dec 19, 2017 | 03:51 PM
17’s on Brembo brakes , hmmm a little tight.
I’m across the ditch from y’all, swing by we’ll figure this iut.
Old Dec 19, 2017 | 05:18 PM
The stock 18's are tight with Brembos. About a 1/2 inch clearance between the caliper and rim.
Didn't know he was running his snows on 17's. With those there was probably very little clearance and no room for error or loose hubs.
Old Dec 19, 2017 | 05:21 PM
I somehow got the idea he has 17's, but couldn't remember if 18 was the right size. I was waiting for you to chime in.
Old Dec 19, 2017 | 05:46 PM
With 17's, you'll need a set of feeler gauges to measure the rim/caliper clearance.
Old Dec 19, 2017 | 07:35 PM
Again, if you have the part numbers of the hubs that were installed, post them up here. We may be able to make some sense out of this.
Old Dec 28, 2017 | 03:07 PM
Yup. Originally, there was perhaps 2mm of clearance left. But they ran fine that way for four winters. Now of course, zero! I put 5mm spacers on and they seem fine for the moment. When I can, I'll grab the invoice and see if I can get a part number for the hub they used. Interestingly, though they no longer list these rims for an SS, Tire Rack does still offer 17" winter rim option for SS w/Brembo if you use their finder feature.
Oldblue, I've actually been up in Welland a bit this last year, so I may catch up with you yet.
Old Dec 28, 2017 | 05:21 PM
Drop on by! LS and SS twins, in IBM.
Old Dec 29, 2017 | 06:27 AM
aradmahogany's Avatar
I have the 16 inch Torq Thrust M's on my LT, and you guys dont even know the half about caliper clearance. I maybe have like a credit card or two worth of space.
jbiesent
44
May 9, 2016 12:11 PM
babeba67
Jan 29, 2014 11:56 AM
helhedded
Mar 22, 2012 06:55 AM
dudeasif
Maintenance and Upkeep
Dec 21, 2011 08:36 PM
red3737
Nov 12, 2011 03:53 PM
