Front Sway Bar Link replacement
Old Mar 18, 2010 | 10:32 PM
Gone Blue's Avatar
Originally Posted by the_shmoo
Per Service Manual
1) Raise and support the vehicle.
2 )Remove front tire and wheel assembly
3 )Replace Stabilizer Shaft Link
Torque nuts to 59 lb/ft.
shmoo, so does that mean that the there would be no weight on the front suspension? Everything would be just hanging free?
Thanks, G.B.
Old Mar 18, 2010 | 11:10 PM
the_shmoo's Avatar
Yes. I have replaced rear sway bar links on other vehicles. Once the weight is off the suspension the bar is relaxed.
Old Mar 19, 2010 | 01:59 AM
txbass06's Avatar
Originally Posted by bunkie
Powergrid makes a nice performance link with hiem joint ends. It's not cheap, but the goodparts never are. WWW.powergridinc.com. 10mm=35 lbs. 12mm=45 lbs.
t
The problem with heim joints under the car is moisture...plain and simple. They have tight clearances so any moisture/debris/pitting causes them to lock up.
Old Mar 19, 2010 | 09:08 AM
Gone Blue's Avatar
Great, thanks shmoo for the clarification! G.B.
Old Mar 19, 2010 | 09:09 AM
Gone Blue's Avatar
Originally Posted by txbass06
t
Bummer, that doesnt leave us much in the way of options does it? G.B.
Old Mar 19, 2010 | 09:20 AM
the_shmoo's Avatar
You are welcome. Let us know how you make out.
Old Mar 27, 2010 | 12:23 PM
Gone Blue's Avatar
Yeah, the new link fixed the clunk on the drivers side! You could not tell it was bad with the car up in the air and weight off of the suspension. It wasnt till I removed the upper link nut that you could feel that the bottom one was shot. I wish they would have made the hex on the ball stud a little bit bigger so you could cleanly get a back up wrench on it. The bottom link was a pain in the a*@ to get off. I had to use a small pair of visegrips to hold the ball stud to keep it from turning. Anyways, we will see how long this one lasts. The original links have lasted 50,000 miles. G.B.
Old Mar 27, 2010 | 12:44 PM
the_shmoo's Avatar
Did you use Genuine GM parts or after market?
Old Mar 27, 2010 | 09:46 PM
Gone Blue's Avatar
GM part from the dealer. $29.00 if I remember right. G.B.
Old Feb 24, 2015 | 04:25 PM
Bahbushkah's Avatar
on my 2006 HHR what can I expect to pay for having my sway bar links replaced? Anyone?
