Gauge Panel 2010 HHR SS
Old Sep 15, 2015 | 09:47 AM
mblandsr's Avatar
Having problems getting the Contrast Section to work (Stuck to right-Highest contrast)......
Old Sep 15, 2015 | 09:52 AM
Do you mean turning the wheel has no effect? That would depend if you are in direct sun or shade.
Right now I'm in bright sun, the wheel does nothing.
Old Sep 15, 2015 | 11:59 AM
mblandsr
Are you talking about the RPD unit on top of the dash ?
Old Sep 15, 2015 | 12:44 PM
OK. I assume you mean the RPD unit. This can be a little tricky the 1st time you try to make any adjustments to the screen. Lord knows, I've played around with mine way too much.
Also not sure why Chevrolet didn't give a good detailed owners manual for this little box of gauges.
Anyhow. I guess you got to this screen :
Once you select this, it goes to the "set" screen :
Now the tricky part. Turn the knob until the Set, Return selectors are NOT highlighted in red. Push the knob once, you should be able to adjust the contrast now.
Push the knob again to get it back where you highlight the Set in red. Push the knob again to set your new contrast level.
Old Sep 16, 2015 | 02:25 PM
mblandsr's Avatar
Thanks To All
Want to thank everyone for the info. I will go out and try when I get off of the CPU. Again THANKS.........This is the Best Web Site I have ever been onn.
THANKS,
mblandsr (Mike)
Compressed
"How To" Tutorial Library
60
Jul 29, 2019 02:22 PM
elvistar
Sep 2, 2010 08:13 AM
2010SilverIceSS
Aug 13, 2010 06:09 PM
