HHR SS 08 and 09 brake loss upon startup
I brought it in for a coolant leak, they said the hose was rubbing and wore through.
I asked them to check the hard brake pedal on cold start problem. They wrote on the receipt "Technician cannot verify customer's concern". What do I do now?
They're keeping it overnight again and will check again tomorrow, but I detected a distinct lack of enthusiasm on the part of the service rep. I've noticed the issue since new but it never really bothered me but with my wife driving the car more now and saying "OH MY GOD, THE BRAKES DON'T WORK!!!" in the morning, I thought it would be a good idea to have it done.
Look up the TSB for this in the the TSB thread. Copy it and take it to them. It is a common issue on all auto HHR SS. It will not cost the dealer a thing to fix it as it is a warranty issue.
The added Vac pump solves the issue plain and simple. Point out to them that it is now a OE item on all auto SS built after Jan 2009. Same for the 2.0 Solstice and Sky.
Please keep us posted.
Um, what Hyperv6 said.
My dealer says he never heard of it but I'm dropping it off sun nite so they can start it mon morning it does it every day to me they cant miss it even if I remote start it and it runs 5 mins the first stop is shaky
Also unless you SS ws built in Dec 08 or before it already has the pump.
'10 stick with Brenbo's here and never an issue. However, I always let it idle off the startup map until the ignition timing comes back in. You will hear the exhaust note change to a quieter tone.
I try be be nice before the beatings resume
I too had no need for the power upgrade but I enjoy the heck out of it.
This is why it took GM so long to fix the issue is that it was also going to be a factory fix and not just a dealer fix. It effected all 2.0 Automatics and they needed to address it.
FWIW I asked ChevyMgr about this in a PM long ago since my '09 SS was built in 3/09. Long story short- any auto SS built around that time and afterwards has the auxiliary pump from the factory. Essentially, any AUTO SS built prior and up to 2/09 should make sure they have the auxiliary vaccuum pump fix done.
Later
Allex
Later
Allex
The only real issue was on the 08 and early 09 automatic SS. They have a TSB to install the vaccum pump on these to solve the issue.
It has nothing to do with the Turbo Up Grade at all.
Nothing to worry about. If the SS you find does not have the TSB pump repair then take it to the dealer and they will retro fit it for free.
The pump is standard on all automatics after Dec 08 or Jan of 09.
Once it is repaired it is no longer an issue. The problem happened on all 2.0 Turbo's even in the Sky and Solstice.
Last edited by Oldblue; Mar 4, 2023 at 12:23 PM. Reason: No sales fishing! Please post a classified ad in our Marketplace!
