I inspected some of the part numbers suggested above (many were discontinued) and also considered some of the MacGyver methods, but the MacGyver parts were not available locally or were quite a bit more expensive. These "sort of" work, you have to force them over the airbox studs with copious force and lube, and the pressure and weight of the airbox and intake plumbing keeps them in relative compression/location correctly. I suspect they will fail soon because of heat and being so stretched over the studs, but for now they are working fine. I paid about half of what this link indicates:
https://a.co/d/atg9yTn |
(Post 939559)
From the "common part number " forum.
Air Filter Box mounting Grommet - GM calls it an "Insulator" - P/N - 12563914 (2.2L/2.4L) - P/N - 25920906 (2.0L) |
| All times are GMT -5. The time now is 08:11 AM. |
