how to remove hhr ss filter housing
Okay I know I'm getting old now I forgot exactly how I removed the air filter box on my SS last year from what I remember you just unscrew the top lid pull the inlet pipe of the side and just pull straight up on the housing and it comes right off
Does that sound about right? |
Yes, there are four clips as well keeping it stable.
looks like there is one torx bit in the back bottom corner driver side to take out first
Ok make that three
Two of which are next to impossible to remove |
just pull REALLY hard, spray a lil WD-40 penetrating oil on the bushings, it helps a lot.
I don't believe the SS and Non SS are the same style of attachment...
my ss never had those clips idk if thats good ro bad. either way it wont budge even with WD40
I just replaced both cam timing solenoids which involves removing the airbox and if mine is anything to judge by, picking up a spare set or two of the mounting grommets would not be a bad idea. All 2 of mine self destructed coming off and we now have 3 more on order. The darn things are $4.55 each so I will try to figure out if they are a standard part for something else. It's always the little stuff they stop making that makes it hard to keep cars up as they get old.
Ira |
Originally Posted by lazaino
(Post 757294)
Ira |
