Knock sensors P0332
Knock sensors P0332
I have low input codes for both knock sensors
sensors are new, fuel has been drained and refilled with 91 as a precursor, I have checked all plugs and wires with a multimeter and they all come out to spec. Anyone know the problem?
Both wires originate at the ECM, different connectors. Doubtful ground is involved. Most likely the ECM connectors or a frayed wire, I would look at the part of the harness that bends around the EVAP purge valve bracket.
Knock sensor 1 code went away for no apparent reason while sensor 2 code remains. I went ahead and replaced the whole wire and sensor again. Code still remains. Is this a ecm issue? I even went as far as to send 3 volts through the wires that run to the knock sensor and read voltage at the other side and there was never a break in voltage no matter how hard I wiggled and pulled. The connection is not the issue. I've done everything 5 times I know for a fact something else is the problem
