loss of brakes
Old Mar 10, 2016 | 04:30 PM
skater's Avatar
loss of brakes
have 08 ss when you first start car and drive off brake pedal to floor hard to stop car after a couple minute brakes are normal if i sit and wait a few minutes after start up and drive off brakes are normal its just driving off after start up
Old Mar 10, 2016 | 05:04 PM
Snoopy's Avatar
If you have the automatic trans, you probably have a car that does not have the "recall' for the vacuum pump install. Do a search on this forum for the info.
Old Mar 10, 2016 | 05:07 PM
https://www.chevyhhr.net/forums/gm-r...-status-50716/
Old Mar 14, 2016 | 11:59 AM
andyb's Avatar
the dealer adds an electric vacuum pump , to supply more vacuum to the power brake vacuum booster for cold start. I didn't get it done, because I don't want any wires hacked, so, I'm just aware that on the 1st brake push, in the morning, you have to use your leg more. by the way - all vw's & bmw's a/ turbo engine's already have a vacuum pump factory installed & they all leak oil & fail - - I know this because I work for an extended warranty company & do these claims all day long.
Oldblue
Nov 24, 2013 11:18 AM
X_EGO_BRAIN_X
Mar 28, 2011 10:32 PM
mrarff
0
Jan 7, 2011 08:15 AM
HillsdaleHHR
Nov 9, 2007 07:31 AM
