lower ball joint
Old Mar 21, 2024 | 01:57 PM
felcan's Avatar
lower ball joint
What is everyone replacing their ball joint on a 2008 ss with fe5 suspension
Old Mar 21, 2024 | 03:34 PM
Over the top is the onlyHHR SS ball joint replacement with correct stub diameter
https://www.overthetopperformance.co...LNF_p_295.html
Old Mar 21, 2024 | 04:27 PM
Otherwise, you would have to replace the entire control arm.
Old Mar 21, 2024 | 04:30 PM
And those aren’t available any longer
Old Mar 21, 2024 | 04:51 PM
Do not get one that says "fits all"!!!!!!
Old Mar 22, 2024 | 07:54 AM
felcan's Avatar
Thanks for info
Old Mar 22, 2024 | 08:36 AM
You are welcome, and if you need to replace the LCA rear bushings use Moog K201285 problem solver ball bushings , they last much longer then the rubber factory bushings
https://www.moog-suspension-parts.com/moog-k201285
Old Mar 22, 2024 | 08:40 AM
felcan's Avatar
Thanks again....I got this as a fixer upper now looking at it I am not sure it has the correct control arms on it
Old Mar 22, 2024 | 09:27 AM
The wrong control arms, because they have the wrong ball joints, can cause damage to the steering Knuckles.
If the control arms are steel, they are incorrect. If they are aluminum, you will want to measure the ball joint stud with calipers.
Old Mar 22, 2024 | 09:39 AM
Ball joint stub must be 20.5 mm
https://www.chevyhhr.net/forums/ss-s...iameter-64831/
Factory lower control arms on the SS had part number on them
Lower Control Arm - SS models ONLY (FE5 suspension)
IMPORTANT: they are only available thru GM - No after-market suppliers make a compatible part at this time, even though they may say the parts they have are for all HHR's
- GM - P/N: 25930724 - Right
- GM - P/N: 25930725 - Left
(note: Do NOT substitute a FE1 or FE3 LCA - the ball joint stub on them is 19.5 mm and is not compatible with the spindle on a FE5/SS which is 20.5MM)
