Map sensor locations amongst other issues
Old Aug 15, 2019 | 08:55 AM
Old Aug 15, 2019 | 08:59 AM
Originally Posted by 985hhrss
Can anyone tell me where to find the part number for that hose?
GM P/N 15909460
I'll add it to the common parts thread
Old Aug 15, 2019 | 09:05 AM
985hhrss's Avatar
I’ve called every wrecking yard within a 200 mile radius and they have a few hhrs but no ss...Got some window switches and window motors wasn’t much else I could pick off of them. Is there anything besides the tune up that has already been done that I should be focusing on for longevity? Ive read something about timing chains causing catastrophic problems which is a bit out of my wheel house but I’m sure I could tackle it...the engine and tranny seem to be really strong which isn’t Surprising since it was senior citizen owned. Ive put 1000 miles on it so far and I just don’t know if I should just get it running well put a down pipe and a tune and then save for a new engine or if it’d be safe to start building on this one. The reason I wanted this hhr is because I know no one around here in south Louisiana will respect it so I want to throw down about 400 to the tires and make them cringe when I gap the piss out of them. I just don’t know if I should spend the time doing that to this engine sitting at 138xxx even though I’m pretty confident it wasn’t dogged out. I’m almost positive most of the problems I’m experiencing are from the terrain it was driven on before I got it
Old Aug 15, 2019 | 09:10 AM
985hhrss's Avatar
GM P/N 15909460
This is the first time I’ve ever had to utilize a forum and I’m at a loss for words to describe how helpful y’all have all been I really appreciate it fellas
Old Aug 15, 2019 | 02:42 PM
At that mileage, I’d replace the timing and balance shaft chains, don’t go EBay cheap , here’s a how to .
Its not that hard, and we are here to assist, and show you how to do the job.
https://www.chevyhhr.net/forums/how-...in-kits-60394/
Old Aug 27, 2019 | 05:05 PM
  #26
985hhrss's Avatar
Update
switched coils around still has a misfire in cylinder 2 so I changed the plug and so far so good. I found that the hose clamp on ic piping from intake to turbo was loose I tightened it still having boost issues so I checked the boost control valve and it allows air to flow through it to the left vacuum hose so I’m assuming that means it’s good. I’m at a loss...bought a new air filter (paper) got a hose in place from air box to fender...I don’t think it’s a boost leak because sometimes I get normal boost(most of the time I don’t). The only other thing I can see is I think the guy bought a cheaper maf instead of the ac delco could that be causing my issues?
Old Aug 31, 2019 | 06:56 PM
  #27
985hhrss's Avatar
Unplugged the Maf and it runs like a mofo
Old Aug 31, 2019 | 07:28 PM
  #28
Just like in post #5?
RJ_RS_SS_350
25
Jun 7, 2018 09:55 AM
v-twins
2.0L Performance Tech
71
Nov 7, 2016 09:04 AM
cannuck
Sep 22, 2014 06:59 PM
Siemer
Maintenance and Upkeep
Jul 12, 2013 02:32 PM
gcsd3742
0
Apr 28, 2009 03:24 PM
