Motor mounts for the ss auto?
#152
Many members here have purchased them (many more on the Cobalt forums).
Haven't heard of any complaints posted.
#153
A bit skeptical of what ? They do work as advertised and are better built than the original OEM part. Only drawback is you will feel more of the engine vibrations since the TurboTech unit is stiffer than the original.
#154
Ok. I understand.
Since this mount is considered a performance part, it may not be worth it for you. Buying this mount for a basic HHR you won't get the benefits of what the mount is designed for.
The factory OEM type mount would probably work fine for normal driving.
edit: Fwiw. Looked up the engine mount listed from the big box stores. Seems they run around
$90- $100.
$90- $100.
#155
Your mount shipped already :)
If you would like another for your other HHRs, PM us we can get you a multi product discount.
These will last much longer than the soft factory ones. Some have them for over 10 years already.
