2.0 5 speed engine R&R
Old 05-11-2020, 01:16 PM
Kc0kfg's Avatar
Well it's time to get started on the SS
Now I know the factory way to drop the cradle,
and I've see guys pull the motor out of the top with an auto.
But with a manual isn't the flywheel and pressure plate going to make it really hard to remove fro. The top?
Let alone getting it back on the input shaft going In
Dropping the cradle is the best way yes?
Kc0kfg is offline
Old 05-11-2020, 01:27 PM
Technical Moderator
Easiest, anyway if you have a lift. Just disconnect the 4 cradle bolts and the 6 strut tower bolts (or pull the axles)(and other stuff) then lift the body off.
donbrew is offline
Old 05-11-2020, 02:07 PM
I just recently completed this. Lowered the cradle, no lift. Make sure to read my post #56, shows the difference between the jacks that I used. https://www.chevyhhr.net/forums/prob...-engine-62561/
Here is fastsuv's thread that gave me the inspiration for the job. https://www.chevyhhr.net/forums/how-...ut-lift-57722/
RJ_RS_SS_350 is offline
fastsuv
06-21-2017 07:48 AM
Bkm0607
09-13-2012 02:39 PM
VictorySpark08
Mid Central
12
06-19-2009 10:31 PM
Lone Ranger
07-21-2008 08:01 AM
WickedHHRLT
01-24-2007 11:29 PM
Quick Reply: 2.0 5 speed engine R&R
