Mounted ss rotors without changing caliper!
as for the warping, my mechanic explained it as this, whoever replaced the brake pads previously, didnt put any grease on the pins, thus not allowing the calipers full freedom of movement, so they stayed clamped longer than they normally would have.
typically, I would do a brake job myself, but as he was looking at an issue Im having in another area already, and I had the pads on hand, he went ahead and put them on for me today. anyways, once I get the newer calipers and rotors on, Im going to have him manually adjust the rear drums as well, just to cover my bases
Im still having a little bit of an issue with identifying the correct brackets, does anyone have a link to part numbers for the specific brackets I need ?
awesome, thank you !
for the record, I know I can use the search function, and have, the problem is I suck at it, Ive never been good using search engines, maybe I use too literal phrasing or too vague, or.... I dont know, I just always have issues with using search functions.
so I apologize for asking questions that I know have been answered.
#26
a perfect example of why I suck, I honestly didnt even know that was possible... and Im not dumb (unless you talk to my wife), Ive been working with comps since mid 90s and building them since 98... but that is hardware lol
