Need help figuring out what this noise is coming from. VIDEO
Old Mar 15, 2025 | 08:57 AM
TurboKid1994's Avatar
Hey y’all, I got a 08 Chevy SS here. Recently did the timing chain job as well as VVT parts. Everything runs great except for this rattle that has appeared after the engine has warmed up, and starts at around 1500 RPM. It’s a very deep rattle And it can be felt just lightly through the gas pedal. The video makes it much louder than it really is, but that’s good. Good so you can hear it well. Hoping it’s not something serious. I did recently run two cans of gum out through the gas.
File Type: mov
Old Mar 15, 2025 | 09:13 AM
Can’t hear it. Hard to hear anything if you’re inside the car. Try opening the hood and recording there.
Old Mar 15, 2025 | 10:01 AM
I can hear it very well. The first small part is smooth and then as I accelerate, you can hear the lower pitch rattle.
Old Mar 15, 2025 | 10:13 AM
PulpFriction's Avatar
Pretty short clip, but I think I hear what you’re talking about. I don’t know, but can’t say that it’s not an exhaust leak. If so, due to the proximity, it’s completely plausible that you would feel it in your right foot.
Old Mar 15, 2025 | 11:27 AM
Well if I can’t hear it then I can’t help you. I’m not going to try and guess.
Old Mar 15, 2025 | 12:13 PM
Timing chain job? Did you replace all guides and the balance shaft chain and guides? Did you install a ZZP front guide? How about that front guide replacement bolt?
Everything installed and all fasteners torqued to specifications?
did you change the oil and filter?
Old Mar 15, 2025 | 02:58 PM
greg8453's Avatar
I think we are chasing a ghost.
Old Mar 15, 2025 | 03:25 PM
I don't have any app that will open that file.
Old Mar 15, 2025 | 08:18 PM
changed everything i could. Torqued with red paint to make sure. Even water pump!
just got done with work at 9:15 pm est and at idle, it does not produce the rattle when goosed
Old Mar 15, 2025 | 08:20 PM
maybe you could try going someplace very quiet and listening to it at different volumes. It’s a peculiar rattle. One that does not happen at idle, but definitely happens under load.
