No cruise, No ESC, Service ESC
This has now happened twice and I was wondering if anyone else has had the same problem or any ideas?
A couple of months ago my cruise control would not engage. I just thought I would take it to the dealer, but after shutting it down and restarting it, it started working again. So, a couple of weeks ago when the cruise wouldn't engage again I shut the engine down and restarted at a stop sign ( I may still have been rolling a little bit). After the restart, the "Service ESC" message came on, then went to "NO ESC". The orange triangle lit up and stayed lit. I tried shutting down and resarting several times but got the same. Again, I thought a trip to the dealer but after an extended shut down I got no warnings and everything worked! Yesterday it did the same thing, but this morning everything is fine :confused: My fear is that I take it to the dealer and everything works, they won't be able to figure it out. Any ideas? |
It may have left a code in the computer so they can find what is going on.
It sounds like a sensor at the hub is going bad? |
I hope you don't get the dreaded "could not reproduce problem" from the dealer.
Cruise control won't work with a ESC, TRAC, ABS or CEL message/light on. By restarting the vehicle you are doing the same as rebooting your home PC. There is still a problem that needs to be fixed and codes should be present to assist in the repair.
THe ESC warning did not come until AFTER the cruise didn't work AND AFTER I restarted. Is there a minimum time I must shut down to reset everything? Just wondering why all is fine after an extended shutdown?
Originally Posted by esmarkey
(Post 308740)
No minimum time on the restart. It may be that when you shut the door you are moving the bad wiring/connector and the problem disappears until the next time it gets moved by a bump or by motion. If you are under warranty take it to the dealer. It should have codes from the lights being on. |
Originally Posted by ChevyMgr
(Post 308754)
I had the same problem with my cruise control it wouldn't engage. This is what I found out check you brake lights and third brake light if one of them is out the cruise will not engage or make sure that the wires are plugin securely.
make sure all the fuses under the hood and pushed all the way in. my message display screen went out one day, i checked the fuses and some of them were loose, after i pushed them in everthing was fine.
Thanks for the info, I will check the fuses/fusebox for loose stuff, then I will mention it when I take it in for other warranty work.
| All times are GMT -5. The time now is 09:41 AM. |
