Normal Temp range
I doubt it’s the thermostat. When the thermostat fails it’s generally shows a temp too low or gives the (- - - - ) reading in the DIC.
Since he just went to the oil change place, I would check their work. Probably opened the radiator cap to check coolant and introduced an air bubble.
I would suggest burping the cooling system.
"always 206F" leads me towards the cooling fan as a possibility. Maybe a clogged or obstructed radiator or just low coolant level. Or, somebody thought a 190 t-stat was better than 180.
While 206-216 is not over heating it is a bit on the high side. Don't use anything other than AC-Delco 131-158 t-stat. The purpose of a t-stat is to keep the coolant ABOVE 180F.
Coolant level should be checked under the pressure cap, not the recovery bottle.
While 206-216 is not over heating it is a bit on the high side. Don't use anything other than AC-Delco 131-158 t-stat. The purpose of a t-stat is to keep the coolant ABOVE 180F….
Oh, wait! There is another plausible explanation! I suppose a defective temperature sensor could be sending bad information.
