Normal Temp range
Old Dec 20, 2024 | 08:24 AM
You need a thermostat.
I doubt it’s the thermostat. When the thermostat fails it’s generally shows a temp too low or gives the (- - - - ) reading in the DIC.
Since he just went to the oil change place, I would check their work. Probably opened the radiator cap to check coolant and introduced an air bubble.
I would suggest burping the cooling system.
Old Dec 20, 2024 | 08:40 AM
"always 206F" leads me towards the cooling fan as a possibility. Maybe a clogged or obstructed radiator or just low coolant level. Or, somebody thought a 190 t-stat was better than 180.
While 206-216 is not over heating it is a bit on the high side. Don't use anything other than AC-Delco 131-158 t-stat. The purpose of a t-stat is to keep the coolant ABOVE 180F.
Coolant level should be checked under the pressure cap, not the recovery bottle.
Old Dec 20, 2024 | 04:09 PM
And to add to those great suggestions, change the Dexcool every 5 years, refill with 50/50 Dexcool.and burp the cooling system
Old Dec 20, 2024 | 05:35 PM
PulpFriction's Avatar
Maybe not the most common defect, but it is possible for a thermostat to open just fine, but at a temp that’s too high. That would explain the “always 206.” What else would?
Good advice. Makes sense to me.
While 206-216 is not over heating it is a bit on the high side. Don't use anything other than AC-Delco 131-158 t-stat. The purpose of a t-stat is to keep the coolant ABOVE 180F….
There really is no other plausible explanation for a system that’s “always 206” (if true) than a defective thermostat. With a properly functioning thermostat, with the car at cruising, the temp would be close to the set point, no fan needed.. A clogged system would cause erratic readings.
Oh, wait! There is another plausible explanation! I suppose a defective temperature sensor could be sending bad information.
OldSwede
Mar 12, 2019 07:44 PM
ecl
Apr 4, 2010 06:31 PM
08blackHHRSS
Sep 20, 2008 03:05 PM
fastsuv
Feb 12, 2008 10:57 AM
Retroburban
South Mountain
26
Jul 22, 2006 09:58 PM
