P0299 and p2261 trouble codes
Old Apr 29, 2019 | 07:15 AM
DrLoch's Avatar
I don't think you can delete the vacuum tank and have it work correctly. There is a reason GM put the tank there to have a reserve supply. The system calls for vacuum at times it's under boost or not "pulling" a vacuum. Without the tank, it has no vacuum to pull from.
Correct, you can't delete the vacuum tank and have everything work correctly.
Old Apr 29, 2019 | 08:23 AM
Originally Posted by WhiskeyshotSS
Yes it is are pointed towards the ac. I will check the cables and o-ring tomorrow.
See post #3.
Old Apr 29, 2019 | 09:04 AM
WhiskeyshotSS's Avatar
I will take some pictures of the lower sensor soon and post them here.
Old Apr 29, 2019 | 09:06 AM
i see, is there a way I can test the tank to see if it still good? When I got the car, all those vacuum lines coming up from the solenoid on the intake manifold were plugged into the wrong spots.
Old Apr 29, 2019 | 09:23 AM
Here is the entire TSB; to see the pix open the .pdf.
tsb.pdf
dirtynapkin
Oct 12, 2016 11:34 AM
JSK
66
Mar 29, 2016 10:59 PM
socalHHRguy
May 24, 2012 04:47 PM
DAVCOXX
Aug 13, 2010 10:52 AM
RodzHHRss
11
May 25, 2010 06:43 PM
