Rear O2 sensor not ready
I have to get my 2008 SS smogged and the rear O2 sensor and evap shows not ready. In California the evap does not have to be ready. I have a new ZZ crate motor. Previous owner put in a 3" Down pipe. I have tried many drive cycles, I called the previous owner to ask if he disabled the Rear O2 in HP tunes. He can't recall. I looked up the tune and I didn't see it disabled. Here are my choices as I see it , but any advice will be welcomed.
1--replace rear O2
2--Put stock tune back in temporarily
3--Make the O2 "invisible" in HP Tunes ( no idea how to to do this)
If anyone has had this problem your input would truly be appreciated.
1--replace rear O2
You do know that the catalytic converter is part of the downpipe? California is very strict about catalytic converters.
Have you visually inspected the system? Is there a properly labelled converter? Is there a #2 O2 sensor?
If it will run with the stock tune, that seems like the easiest.
I think the O2 sensor monitors runs continuously or twice a drive, so I don't know how it could "be not ready".
I suppose you could try a battery disconnect lobotomy.
