Possible fuel pump issue
Old Jun 11, 2019 | 12:55 PM
I’m more inclined to , stop turning the engine over and remove the valve cover to see if the front guide broke and the timing chain is loose.
then the engine front cover to replace the chains and guides and tensioners.
Old Jun 11, 2019 | 02:13 PM
I see, to prevent potential further damage to the valves and pistons. Good thinking.
Old Jun 11, 2019 | 06:20 PM
Sometimes, I don’t need the loud metal crunching to remind me , these are close tolerance engines.
Old Jun 14, 2019 | 03:47 PM
mclc126's Avatar
Originally Posted by donbrew
Since this is exactly the symptom that the recall is supposed to fix, has it been done?
Does the motor turn over?
Has anybody checked the timing chain?
Finally got to work on the car and the timing chain is broken. Now to figure out if the motor is ok. Any helpful hints?
Old Jun 14, 2019 | 03:57 PM
If the timing chain actually broke, then it's almost certain that the engine is trashed. These are interference engines which means when the chain breaks, the pistons will contact the valves. Especially if you've been trying to get it started by turning it over as you posted.
Broken chain = major damage. Start looking for another engine.
Old Jun 14, 2019 | 04:22 PM
  #26
No choice, pull the cylinder head . Or rent a boroscope.
You might be able to see the piston tops through the spark plug holes .
Thielz
Aug 2, 2018 03:35 PM
Sam621
Dec 14, 2015 06:43 PM
Cardwiz428
Jul 7, 2008 10:40 PM
mizzouHHR
Nov 14, 2006 05:47 AM
