reduced power, engine disabled
Old Oct 14, 2018 | 01:33 PM
Hi Jane, to the forums!!
Thanks for introducing yourself, now maybe some more information about the issues you're having with the HHR.
Old Oct 14, 2018 | 02:20 PM
Great ,Jane. Nice to see you have a sensor humour and a need for speed, with an eye for a cool ride!
Old Oct 14, 2018 | 03:49 PM
jamorg's Avatar
Thank you,........Jane from Georgia
Old Oct 14, 2018 | 05:11 PM
So, you just don't feel like elucidating us about you problem?
I suspect the infinite scroll thing is confusing you. Hint: there are now 14 posts in this thread.
Old Oct 14, 2018 | 06:24 PM
I can turn off the infinite scroll and the related threads if you like.
Old Oct 14, 2018 | 06:35 PM
Might not be a bad idea...
I can work with it but it's just weird.
Old Oct 14, 2018 | 09:07 PM
I’m working on a how to.
Old Apr 27, 2020 | 12:10 AM
jamorg's Avatar
2009 hhr ss
Cutting out while driving. Feels like you are cutting the switch on and off, making jerking movement.
was occurring occasionally, now more often. I changed plugs, did not help. Check engine light has not been on.
Last edited by jamorg; Apr 27, 2020 at 12:19 AM. Reason: I did not add all info needed to pose problem.
Old Apr 27, 2020 | 04:37 AM
Cat Man HHR's Avatar
Does just the engine cut off ?
Or does things like headlights, radio, blower motor do it at the same time when on.
Old Apr 27, 2020 | 06:51 AM
Try a battery lobotomy, disconnect the negative cable for a full 30 minutes. While you’re waiting, check the ground wires and look for dirt and corrosion
