speed sensor ring
Anyone know if there is a difference between wheel hub assemblies of the SS vs non SS? In particular are the speed sensor rings different in number of teeth or of different diameters?
Thanks. |
Sensor is integral to the hub/bearing. The part numbers are different I think.
SS Interchange Part Number: 513214;BR930317;HA590070;WB13214 LT/LS Interchange Part Number: 513206;BR930433;HA590086;WB13206 Taken from eBay. |
The SS has larger, front, diameter axles.
I remember a few years ago, when I wanted to put 4-lug wheels on my buggy, I thought that it would be easy, to just use the rear, 4-lug wheel hubs, from a Cobalt. They swap over easy, & looked the same, but my ABS light came on, because of a different ring count ...:skull1: I had to get all 4 of my wheel hubs, redrilled, for my 4lug wheels. |
| All times are GMT -5. The time now is 03:10 AM. |
