SS oil pan
Old May 20, 2011 | 06:52 AM
o6designs's Avatar
SS oil pan
Will the the oil drop straight down to remove ? Or does the engine need to be lifted off the mounts in order to drop the pan ?---Bob
Old May 20, 2011 | 09:48 AM
asanti's Avatar
Are you planning on swapping oil pans for some reason, or just doing your 1st oil change on an SS???? In either case you don't need to touch the motor mounts to do an oil change OR to swap out the actual oil pan.
Later
Allex
Old May 20, 2011 | 10:47 AM
o6designs's Avatar
I had a rock about 1.5 in X 3.5 in rectangle shaped get kicked up tumbled and bouncing off the pavement from another car . It went up and under my car and just grazed the oil pan making a small mark . Not even a dent ! Beside the mark it cracked and is leaking . Gm said $500 to repair and won't cover repair - which is understandable . Just got back from Chevy dealer - they looked it up on the computer-2.2 & 2.4 you don't have to lift but 2.0 you do . Boy are those oil pans thin material + cast aluminum !!---Bob
Old May 20, 2011 | 10:49 AM
ChevyMgr's Avatar
The dealer is correct. 2.0 will need the engine mount removed so you can lift the engine up a little, to get the pan out.
Old May 20, 2011 | 10:53 AM
bad03xtreme's Avatar
Sorry to hear that, that blows!
Old May 20, 2011 | 11:15 AM
asanti's Avatar
Later
Allex
I stand corrected then. To the OP: I hope you can get this fixed ASAP!
Later
Allex
Old May 23, 2011 | 07:10 AM
o6designs's Avatar
The engine only had to be lifted a couple of inches . It took longer to get the air cleaner box and windsheild washer out from under the hood than it took to get the pan off. The dealer wanted close to $500 . Actual costs -$59 for an engine suport (Thankyou Harbor Freight)-$35 at a local hotrod shop for welding + a tube of silicone (no pan gasket) . The plus is being able to keep the suport. The dealer did offer me a low price of $142 for a new pan if I needed one. I at first thought that was still high until I saw what a complicated casting it was.---Bob
Old May 23, 2011 | 07:27 AM
o6designs's Avatar
Our "little sewing machine" motors are sure neat . Don't look like any chevy engines I've ever been inside of before .---Bob
Old May 23, 2011 | 09:57 PM
IgottaWoody's Avatar
Should ahve checked with your ins co.....had a misplaced starter kicked up from a box truck and wound up under my truck...took out the tranny pan, left header and crossover tubes...while they didnt cover 100%... 50% is better then nothing..didnt even question the headers....and got a better tranny pan!
Old May 24, 2011 | 08:41 AM
o6designs's Avatar
It cost me $94 + a tube of silicone. That's cheaper than my $250 deductable any day of the week !---Bob
