Struts
Old Sep 5, 2019 | 08:33 AM
The Struts and shocks , no , springs, yes
Old Sep 5, 2019 | 09:40 AM
Lethal Tendencies's Avatar
I was thinking about buying these. But not if it effects ride height
https://www.summitracing.com/parts/mog-st8597r
Old Sep 5, 2019 | 10:04 AM
Those are for LS/LT, so they are FE1 or FE3. Not FE5.
No one has reported finding FE5 strut assemblies.
Old Sep 5, 2019 | 10:22 AM
I would ok with a FE3 strut assembly as long as the ride height doesn't change.
Old Sep 5, 2019 | 10:40 AM
If they're FE1 or FE3 replacements then they will have the LS, LT springs. Pretty sure those will make your car sit higher than stock.
You could buy those and put in your SS springs from your old struts. Then it would have the same ride height as before.
But, then you would be using soft ride struts with the SS performance springs. Not what I would call a good combo.
Why not just find the SS FE5 replacement struts as we mentioned before ? (And I thought a few posts back you said you were going to do that )
Old Sep 5, 2019 | 10:56 AM
FE3 is "sport" FE5 is "performance"; maybe they are close. Sem to remember someone with a yardstick determined SS was a bit lower.
Yours appears lower than Oldblue's and his is lowered. I wonder if yours isn't lowered already, in that case new springs would increase ride height (no matter which)
Old Sep 5, 2019 | 11:26 AM
Stock FE 3 springs in my 2011, much higher then SS FE5 springs
as for the struts , I see slot of confusion in this list ,
https://www.rockauto.com/en/catalog/...ion,strut,7584
Old Sep 5, 2019 | 11:42 AM
Just looking for something quick an easy
Old Sep 5, 2019 | 01:11 PM
It’s not quick and easy , if you don’t like the ride afterwards.
Old Sep 5, 2019 | 02:17 PM
looks like my only choices are ACDelco or KYB. Both Rock Auto and AMAZON have good prices. I think I can rent a a spring compressor from the local AUTOZONE
