P2261 code
P2261 code
So after 80k miles I am having first problem with my ss. Couple of days ago I had to remove air box. And when putting everything back I forgot to conect map sensor. Drove couple of miles and check engine light went on. I stopped and conected map sensor back. Than disconnected the battery to reset the ecm and light went away. Then yesterday it came back. I stopped at AutoZone and they pulled the code p2261. Which is for BOV stuck closed. The car still runs fine,producing 20+psi. So any idea what I should do next? Thanks in advance.
Just a FYI.
MAF sensor (not MAP) is the one on the air filter housing.
Our SS's don't have a BOV. They have a BPV (bypass valve)
I would try clearing the codes again. If it comes back with the same number, then check the vacuum connections for the BPV.
Last would be to pull the BPV cover and check the spring and rubber diaphram.
Just 3 small bolts to remove the cover.
Just a FYI.
