Engine reduced
You can have a look through this thread https://www.chevyhhr.net/forums/prob...0-p0601-47411/
But for your 2005 Cobalt, you would be better served at a Cobalt forum. HHRs were not made in 2005, so there may be some real differences. Here is the Cobalt forum I linked to in your other thread https://www.cobaltss.net/forums/
P0340 check for loose wires per
https://www.obd-codes.com/p0340
P0601 also I’d check for loose connections at the PCM
https://www.obd-codes.com/p0601
It can’t hurt!
There are sellers on EBay that sell ECM’s programmed to your VIN
It can’t hurt!
That is a very basic thing. If you can't find it then you need to pay a mechanic. P0601 may mean the ECM/PCM is fried; any chance someone touched something under the hood with a jumper cable just before this started?
From what you have said; you need a new ECM and ICM. A good mechanic with expensive equipment should be able to handle it, but a dealer definitely could.
You might be able to get a used ECM programmed to your car on ebay, making that pretty much plug 'n play(except maybe needing a computer to sync the CKP). Replacing the ICM is plug 'n play.
If you don't understand that you need a pro to do it.
It likely would be two hours labor at whatever they charge per hour, but they may be reluctant to install parts that were not supplied by them. Call them and ask for an estimate?
Warranty on a 13 year old car? No. I would not even inquire with the dealer on that question.
