Rebuilt turbo problems
Old 08-13-2018, 05:22 PM
BlackSS200k's Avatar
Replaced turbo with rebuilt unit, drove about five miles lost boost. After inspection found the wastegate valve rod was disconnected. I reinstalled the rod but think that it maybe out of adjustments. Now the boost fluctuates, not really sure what’s going on. I don’t have any turbo experience.
thanks,
James
BlackSS200k is offline
Old 08-13-2018, 07:19 PM
You should contact whoever sold you the defective turbo.
RJ_RS_SS_350 is offline
Old 08-13-2018, 08:48 PM
Thanks for the sound advise! I’m working with them now. However, I’d rather not take the turbo off if there is a way to adjust on the car.
Old 08-14-2018, 09:18 AM
Cat Man HHR's Avatar
OK I did find some info on adjusting the wastegate rod, but not a hard core measurement. Look at the last step.
http://westersgarage.eidnet.ca/LNF_Turbo_Restrictor.pdf
Is there a way to put air pressure to the can ? Not saying this is the problem, but it is a possibility the diaphragm in it has a small leak. With some air pressure on it, spray soapy water and see/look for bubbles.
Rough to diagnose not being there.
Cat Man HHR is offline
Old 08-14-2018, 08:07 PM
Understand that, I just replaced my turbo, what a pain!! But if you start tinkering with it, you may find that they will not honor any warranty.
Old 08-14-2018, 08:25 PM
I sent them pictures of the rod, not connected to the valve. If I’m not allowed to reconnect and adjust, I shouldn’t be dealing with them. I don’t want to take it off if it’s not necessary.
Dharkons
11-29-2017 04:42 AM
Silverfox
01-24-2016 03:51 PM
5speed4
06-05-2013 09:10 AM
prod
05-26-2012 11:55 PM
SPPD
07-16-2008 01:22 PM
Quick Reply: Rebuilt turbo problems
