Turbo Tech Racing motor mounts
#44
#45
You just need a jack to support the engine up while you flip mounts. It is 3 nuts and 2 bolts to change over the mount. It is easier than changing your oil.
#47
Use a block of wood on a floor jack to protect your oil pan.
Place jack and wood under oil pan , lift just to take the weight of the engine.
Remove the two nuts from the frame studs,
Remove the three bolts from the engine mount,
Lift out OEM mount and place in Turbo Tech Racing mount.
Replace the three bolts then the two nuts.
Torque to specs.
Lower the jack and wood.
Test drive SS.
Your done! Enjoy.
Torque to specs.
Test drive SS.
Your done! Enjoy.
#48
#49
Torque to specs.
Test drive SS.
Your done! Enjoy.
Torque to specs.
Test drive SS.
Your done! Enjoy.
