Chevy HHR Network
-   Supporting Vendors (https://www.chevyhhr.net/forums/supporting-vendors-25/)
-   -   Turbo Tech Racing motor mounts (https://www.chevyhhr.net/forums/supporting-vendors-25/turbo-tech-racing-motor-mounts-47256/)
TurboTechRacing 02-11-2018 05:36 PM
Back in stock!
Casa Del Gatos 02-17-2018 07:49 AM
As a new SS owner (auto) I am considering this to combat the torque steer. How hard is it to install the one for an auto/how long should it take?
TurboTechRacing 02-17-2018 07:54 AM
Takes about 15 minutes to install, very simple. Comes with instructions.
Casa Del Gatos 02-17-2018 08:27 PM
Do you need a lift or a jack or what? Can you post the instructions? Maybe just cut and paste them?
TurboTechRacing 02-17-2018 09:05 PM
Instructions are print copy only.
You just need a jack to support the engine up while you flip mounts. It is 3 nuts and 2 bolts to change over the mount. It is easier than changing your oil.
firemangeorge 02-17-2018 10:25 PM
Aaron
I'm meeting up with Casa Del Gatos in the morning. I'll show him how easy it is to replace the mount.
I'm sure I still have the old instruction sheet somewhere.
Oldblue 02-18-2018 07:15 AM
Use a block of wood on a floor jack to protect your oil pan.
Place jack and wood under oil pan , lift just to take the weight of the engine.
Remove the two nuts from the frame studs,
Remove the three bolts from the engine mount,
Lift out OEM mount and place in Turbo Tech Racing mount.
Replace the three bolts then the two nuts.
Torque to specs.
Lower the jack and wood.
Test drive SS.
Your done! Enjoy.
TurboTechRacing 02-18-2018 07:59 AM
Originally Posted by firemangeorge (Post 838713)
Aaron
Sounds great!
Torque to specs.
Test drive SS.
Your done! Enjoy.
Sounds right :)
TurboTechRacing 05-17-2018 05:25 PM
Back in stock!
