Supporting Vendors Promotions, specials, and group purchases by authorized Supporting Vendors ONLY
Turbo Tech Racing motor mounts
Old Feb 11, 2018 | 05:36 PM
  #41
TurboTechRacing's Avatar
Former Sponsor
Back in stock!
Old Feb 17, 2018 | 07:49 AM
  #42
Casa Del Gatos's Avatar
As a new SS owner (auto) I am considering this to combat the torque steer. How hard is it to install the one for an auto/how long should it take?
Old Feb 17, 2018 | 07:54 AM
  #43
Former Sponsor
Takes about 15 minutes to install, very simple. Comes with instructions.
Old Feb 17, 2018 | 08:27 PM
  #44
Do you need a lift or a jack or what? Can you post the instructions? Maybe just cut and paste them?
Old Feb 17, 2018 | 09:05 PM
  #45
Former Sponsor
Instructions are print copy only.
You just need a jack to support the engine up while you flip mounts. It is 3 nuts and 2 bolts to change over the mount. It is easier than changing your oil.
Old Feb 17, 2018 | 10:25 PM
  #46
Aaron
I'm meeting up with Casa Del Gatos in the morning. I'll show him how easy it is to replace the mount.
I'm sure I still have the old instruction sheet somewhere.
Old Feb 18, 2018 | 07:15 AM
  #47
Use a block of wood on a floor jack to protect your oil pan.
Place jack and wood under oil pan , lift just to take the weight of the engine.
Remove the two nuts from the frame studs,
Remove the three bolts from the engine mount,
Lift out OEM mount and place in Turbo Tech Racing mount.
Replace the three bolts then the two nuts.
Torque to specs.
Lower the jack and wood.
Test drive SS.
Your done! Enjoy.
Old Feb 18, 2018 | 07:59 AM
  #48
Former Sponsor
Aaron
Sounds great!
  #49
Former Sponsor
Torque to specs.
Test drive SS.
Your done! Enjoy.
Sounds right :)
Old May 17, 2018 | 05:25 PM
  #50
Former Sponsor
Back in stock!
