15" tires?
Old 07-15-2018, 05:53 PM
OldSwede's Avatar
15" tires?
I have a like- New set of 215/65R15 Blizzak tires that I would like to use this winter on an HHR. Possible?
OldSwede is offline
Old 07-15-2018, 05:59 PM
Technical Moderator
If you could find wheels that are 15 inch with a 42cm offset and a 110X5 bolt pattern. Have to be all 4.
You would have to check if the rims will fit over the disc brakes, I doubt it maybe.
donbrew is offline
Old 07-15-2018, 06:11 PM
OldSwede's Avatar
Yeah, my hope was that someone out there had tried it and could give me a recommendation as to wheels. The Blizzaks were on my previous Honda and are unbelievable in the snow. Only 3k miles on a $500 set of tires and I am hoping I can use them.
OldSwede is offline
Old 07-15-2018, 06:14 PM
Wow, that's gonna look like some kind of monster truck or something.
I know you meant 42mm.
RJ_RS_SS_350 is offline
Old 07-15-2018, 06:33 PM
Technical Moderator
didn't type "inch" anyway.
donbrew is offline
Old 07-16-2018, 07:39 AM
The Malibu Max came with 15 inch rims , 5 x 110mm bolt pattern and our size disc brakes up front. I think it was 2005 model year
Oldblue is offline
Old 07-16-2018, 03:02 PM
Cat Man HHR's Avatar
Originally Posted by oldblue
the malibu max came with 15 inch rims , 5 x 110mm bolt pattern and our size disc brakes up front. I think it was 2005 model year
2004-07
But could be wrong.
Cat Man HHR is offline
Old 07-16-2018, 04:33 PM
According to our friends at RockAuto, both bolt patterns were on the Malibu, so did deep at your local pick a part or order up four new steelies with the 110mm bolt pattern
Oldblue is offline
Old 07-29-2018, 02:05 PM
OldSwede's Avatar
I'm going to try
using a set of spacer/adapters, 5X110 to 5X114.3, 3/4" thick, and see if I can use my older 15" Honda CR-V wheels and Blizzaks. I';ll give you all a report, either way. Adapters will be here Wednesday.
OldSwede is offline
Marzipan
12-19-2008 10:18 PM
da_loca
12-08-2006 12:34 AM
Lee In Calfi
07-19-2006 07:22 AM
Quick Reply: 15" tires?
