2009 hhr ls
Please help me!
Why is my bolt pattern measuring out to 105mmx5 i literally can not find rims that fit |
All models and years of HHR’s have a 110x5 bolt pattern………………….
Unless someone, somehow changed all the hubs to a different size. |
(Post 937602)
Unless someone, somehow changed all the hubs to a different size. The equals out to 104.77 mm right? Thanks Amanda |
:welcomewagon: to the forums! It really is 110.
(Post 937605)
and thanks! |
Originally Posted by the_shmoo
(Post 937607)
Measure the diameter of the stud circle thru the center of the hub.
like this? tganks https://cimg1.ibsrv.net/gimg/www.che...504e030c5.jpeg Amanda |
Well. All that picture shows is that you have the wrong spare tire.
Measure a rim that is “on” the car. |
Originally Posted by awilder
(Post 937608)
I’m sorry I just don’t know what the means, like from the bolt hole directly across ?
Could just ask the vendor for 110X5. Let them do the work.
I always thought "bolt circle" meant the DIAMETER of the centers of the bolts. Draw a circle through the centers of the holes, a line passing through the circle center to diagonal points on that circle. As in the ". Measuring as shown it he pic is a chord not a diameter. However, using the OUTER edges (instead of the centers) of the bolt holes makes up for the difference. |
