20s front 22s rear think it a work
Well that sucks lol.guess niether one wheel work I just thought if I put a bigger wheel on the rear it would just look bigger n add one size bigger tire in the rear just want differnt look .
I see some guys going with staggered wheels on their FWD vehicles that make them look like ahem..Old Sckool RWD. Maybe 215X20 front 245X20 rear would look cool, keeping the same tire height should avoid trac-control issues.
With coil spring spacers you need the U shape ones I jacked up the rear removed both wheels removed the upper bolt from the shocks and the rear axle dropped down enough to lift out the stock springs place the spacer ( I used a 1 inch ) in the cup U side up then the spring sits in on top then replace Springs, Shocks & Wheels. Done
JEGS has them for $ 11.99 each. they are not sold in sets
any more ? just ask . )
well bustin Balls is old school ... Don't let it harsh yer buzz man ...just playin around no one meant any harm my man.
Actually trying to do the same thing but with 16-17 in front 17-18 in back , want a slight angle but subtle smooth kinda thing also want to do a lower offset too on the rear to give a slightly beefeir appearance too...Unfortunately have not done all the math formulations yet as I wont be able to do it untill probably Jan. some time!
