55mm offset wheels???
Old Apr 12, 2010 | 01:32 PM
prod's Avatar
Thanks very much for the info.
Old Apr 12, 2010 | 01:47 PM
djr1973's Avatar
I have Solstice wheels on my HHR and I used 1/4" spacers on all 4 wheels. Didnt change out the studs though, I bought some Extended Tip Lug Nuts and no problems.225/45R18 tires on mine also. When I first installed the wheels and tires they rubbed on the strut in the front so I had to space them out to avoid that.
Old Apr 12, 2010 | 09:04 PM
B@work's Avatar
Spacers on the rear? Did you do that so the off set is the same all the way around?
Old May 2, 2010 | 08:21 PM
ymerej_mortsdnil's Avatar
Question 245/45/18?
Anyone know if a 245/45/18 tire will work with proper accessories?
Old May 3, 2010 | 04:40 PM
Talvanos's Avatar
245/45/18s will throw you speedometer off considerably. Your speedo will show you going 56.9 when you are actually doing 60. With 245/40/18s your speedo will show you going 59 when you are doing 60, 245/35/18s will show you doing 61.3 when doing 60, all the previously mentioned tire sizes will work with 8" wide rims, and 255/35/18s will show you doing 60.6 when doing 60 but requires 8.5" wide rim. Hope this helps.
JAMIROBri
Tires & Wheels
10
Sep 19, 2011 12:25 PM
MNBullyBoy
Tires & Wheels
Dec 22, 2009 08:26 AM
Michael20832
Tires & Wheels
Nov 11, 2008 06:35 AM
PhoS
0
Jul 9, 2007 01:03 PM
