bolt pattern?
Old 03-21-2010, 06:12 PM
kingd1's Avatar
I have an 06 and will be ready to replace tires soon. Was thinking about putting steel rims (painted) with white walls and baby moons. I have heard that if I choose to do this I will have to make some changes. How extensive, and what kind of changes will be required to do this?
kingd1 is offline
Old 09-28-2018, 09:14 PM
Arturo Lopez's Avatar
I'm looking to put some 18 inch rims and wheels in my 2009 hhr but the bold pattern on the rims is
5-115 and the hhr has a 5-110 bolt pattern what kind of adapter do I need and where can I find the adapters
thanks
Arturo Lopez is offline
Old 09-28-2018, 09:40 PM
Technical Moderator
Well,, if you are into tempting death; you would get an adapter that goes fro 5X110 to 5X115 from a specialty rim shop. Why not just get 18 inch rims that are made for the job?
donbrew is offline
Old 09-29-2018, 07:12 AM
X2. But if you already have the rims , this style adapter is required
https://www.ebay.com/itm/5x110-to-5x...0720525?_ul=CA
remember , these must have the fasteners torqued properly!
Oldblue is offline
Old 12-09-2018, 12:04 PM
John Manus's Avatar
Adapters
adapters of good quality are made of billet aircraft aluminum and Bolt on to your current lugs and provide a new set of lugs. They are safe when properly torqued . They are used on duallies to allow for mounting of semi wheels and can hold just as much as your factory hub can so not cheating death however spacer plates are a bad thing cause they use some of the students length
John Manus is offline
Old 12-09-2018, 08:24 PM
d0sitmatr's Avatar
keep an eye on stock stud bolt length, if its above the edge of the adapter, you could have some major problems down the road (pun intended... lol)
seriously though, if studs stick above the lip, you have to either shave them down or replace with a shorter stud.
d0sitmatr is offline
Biggiedog70
Tires & Wheels
31
04-17-2014 04:36 PM
bartSS
12-31-2008 03:06 PM
Ern
04-03-2007 02:21 PM
slamed87lincoln
05-08-2006 04:47 PM
fubar
02-20-2006 02:13 PM
Quick Reply: bolt pattern?
