Cheap replacement steel wheel
Just put some new tires on and the shop showed me a bent wheel. Now I put 35k on the last set of tires and noticed no abnormal wear on the tread. I'm debating whether I even need to replace it. I watched the tire spin after balancing and it looked fine.
I wanted to ask if there were any cheaper options for replacing one steel wheel (#1 below) than what I found at GMPartsDirect.com which with shipping and tax comes out to $101.85
Thanks.
Thanks.
Hit an auto wrecker and see if they have an equivalent steel wheel. At that price of $101, one can get a cheap mag!!! Or see if there are shops in your area that will straighten a steel wheel for cheap. Your tire store or dealer can likely point you in the right direction.
