Cobalt 5 lug fit HHR?
I found a set of Drag DR-33 wheels off a cobalt, they are 17x7.5 with 42 offset will they fit my 2010 LS wagon? They are complete with TPS sensors I would think they would work with the HHR TPS system
Should work Glenn, if the sensors are 315 Mhz.
Make sure they are 5 X 110 mm bolt pattern |
I was thinking the 7.5" wide might be a problem.
Originally Posted by Glenn LaBonte
(Post 849317)
HHR SS's use a 7.5 inch wide rim. |
Lotsa discussion about running slicks..... https://www.google.ca/search?q=HHR+w...iw=375&bih=626 https://cimg7.ibsrv.net/gimg/www.che...0db9beca2.jpeg They fit this SS and the LS/LT fenders are the same width. |
