H&R wheel spacers
Some Volkswagen and Audi guys around here are using H&R wheel spacers. My question is if any HHR's are using them, more specifically the SS? I know they make them already I checked their site. If so has anyone used them along with Pedder springs?
I did a search and it was short lived with not much info. Kinda disappointing since there seems to be many low HHR's. |
H&R makes good spacers, but I went with custom made ones for my application.
In my opinion it depends on how wide of spacers your gonna use. As you start getting wider on spacers you'll want some that are hub centric, I even went as far as ordering spacers that were hub centric to my hub and hub centric to my rims both so they ran perfectly true. If your running thin spacers you can probably get by without hub centric, but for me that might just be asking for problems if you don't get them centered properly, best bet would be to atleast have the spacer hub centric to the hub side. |
Where to get them and how much do they run? I was looking to get some 20mm spacers, or 1" even to push all 4 wheels out a bit.
Where did you get yours custom made at HHRSouth?
http://www.motorsport-tech.com/
You only need 2 for the front, I run 18x8 wheels with 245/40-18 tires. The back clears without spacers. I am at stock height for reference. I ordered 15mm spacers (ordered some arp wheel studs from jegs) and they have worked flawlessly. Seriously the aftermarket rims and tires on the HHR SS probably have ran the most true at all speeds more then any other custom wheel I've had on any other car, even better then some that didn't require spacers lol. |
