HHR LT vs. LS Wheels & Studs
Old Jun 24, 2010 | 01:18 PM
tplyons's Avatar
My HHR is an LS but I upgraded to LT wheels from eBay. Using stock LT wheels, I apparently stripped the lug studs while mounting the wheels. Are the LS studs shorter than the LT since the steel wheel is thinner than the alloy?
Old Jun 24, 2010 | 01:22 PM
Not sure about that, but my 2LT comes with a steel wheel for a spare (yes it works too)
Did it seem that there were only a few threads before it was in contact with the LT wheel?
Old Jun 24, 2010 | 03:49 PM
Talvanos's Avatar
No there is no difference between the LS and the LT from 06-09. P# 9595178 about $3.50 a piece.
Old Jun 24, 2010 | 06:18 PM
tplyons's Avatar
Yes, I did notice this, but there's no way I stripped them while mounting the tires.
I'll be finding some new lug nuts with extended reach.
Old Jun 24, 2010 | 06:29 PM
It may be that the lug nuts are different, were you using the LS or the LT lug nuts? Extended reach should do the trick......
Old Jun 24, 2010 | 07:12 PM
urbexHHR's Avatar
Are there different lug nuts? When I upgraded from my 16's to factory 17"s, I noticed the lug nuts go pretty far into the wheel...
Old Jun 24, 2010 | 07:20 PM
Don't know if there are or not, if they are the same I can't see how they would strip.
Old Jun 24, 2010 | 08:56 PM
tplyons's Avatar
They're supposed to be stock LT lug nuts, according to the seller.
However, they're 13/16" OD, which is incorrect for the HHR according to my dealer.
So I need to find proper chrome lug nuts with extended reach. Any ideas?
Old Jun 24, 2010 | 09:34 PM
skyeglen's Avatar
Every time I run accross a torque number or a bolt size I jot it down on a page in the HHR notebook.
If I wrote it down correctly on my specfications page the lug nuts are 19mm and the studs are 12mm X 1.5
Old Jun 28, 2010 | 07:45 PM
tplyons's Avatar
Well, after farther inspection, I have a couple studs that are still stripped, and one or two where the threading is messed up.
At this point, I'm looking to replace all 20 studs, and have a new set of lug nuts, so I can stop dealing with all this. Do you know if there are harder studs available? I'm not much liking the OEM ones if I'm still having this problem.
