increase tire size
Old Sep 15, 2009 | 04:15 PM
Derf's Avatar
increase tire size
i currently have -215 55 r16 - i have my eyes on 4 rims and tires that are 17inch - 225 50 17 moving up to these > will this cause any haertaches or future problems ?? thanx in advance
Old Sep 15, 2009 | 09:56 PM
HHorange's Avatar
They should work out fine for you...........
Old Sep 16, 2009 | 01:05 AM
lvhhrpanel's Avatar
I have 18" wheels with 225 tires on my HHR, no problems.
Old Sep 16, 2009 | 02:26 AM
jeffs396's Avatar
I put michelin 225/50/17s on my HHR, and even with eibach pro lowering, no problems!
Old Sep 16, 2009 | 11:31 AM
saltyfishguy's Avatar
I went from factory 16 to factory 17 and lowered with gl's, it's fine.
Old Sep 16, 2009 | 12:40 PM
mgfred's Avatar
Isn't there something in the car's computer that has to be set for 17" wheels?
Fred
Old Sep 16, 2009 | 12:42 PM
HHR_style's Avatar
Speedo
Fred
Yeah, doesn't it mess up the speedometer reading?
Old Sep 16, 2009 | 01:16 PM
solman98's Avatar
It's not the wheel size that affects the speedo, it's the overall height of the tire. If you start with a 26" tall tire, switch to a bigger rim, lower profile tire and are still only 26", your speedo will be the same. It's only if you go with a taller or shorter overall tire it throws the speedo off.
This may help.
http://www.1010tires.com/TireSizeCal...?action=submit
http://www.miata.net/garage/tirecalc.html
Old Dec 3, 2009 | 11:58 PM
215/50/17 = 25.5", 225/50/17 = 25.9" Diff of only .400 & only .200 higher on ride height.
That in total is only about a 1% - 1.5% increase in tire overall height, I believe..
Which would slow the speed-O only by 1% - 1.5%...........Almost un-noticable IMO.
hurst2001
Tires & Wheels
Jan 5, 2015 08:48 PM
Canesfinsfan83
Tires & Wheels
Feb 8, 2012 05:50 AM
denny
Tires & Wheels
16
Feb 4, 2011 03:41 PM
Mike B.
Tires & Wheels
Mar 3, 2009 01:47 PM
marksand
Tires & Wheels
Aug 5, 2008 02:16 PM
