Will these saab wheels fit an ls that has 16" steels on it?
Thinking of buying these wheels with perelli p6 tires, would be cool if I could just bolt them on.
I was able to find a website that said the saab wheels were et49 and I know hhrs are 42 do you guys think it would rub on the strut?
The hub size and lug nut seat type are critical as well. Research the wheels to find these things out, or just seasrch for the car they were on. Buying non OEM rims can be a pain, but as long as offset is within spec and the seat type as well as hub size, you are good. I measured my American Racing Torq Thrust M wheels before installation, and they were machined perfectly right down to the millimeter. Being that SAAB was part of the GM family, I am sure they will fit and be virtually the same as the HHR. Offset wise, you can safely go to +35 MM. Thats where mine are at. I think that is the absolute lowest you can go, though.
DCNyberg
Tires & Wheels
08-21-2014 09:49 AM
Mateng
Tires & Wheels
21
04-18-2011 03:31 PM
Sirjenx
0
09-18-2009 05:28 PM
