Snow Tire Performance
I have compared other brands of winter tires on a snow and ice covered test track and found Bridgestones to be marginally better and way better than ordinary tires with mud/snow-rated treads.
Snow TIre Performance
All...
I feel the need to remind you to read you owners manual...
[B]Snow chains are not an option[B]
Not enough wheel clearance with the stock 17inch
I have an 07 2LT, 2.4 Auto, all stock ..
I live in central Ca,, so wont see snow much,,
although I am driving to Reno this coming weekend and that
requires driving up to 6800 ft elevation over Donner Pass,,,
Tire Chains!
All...
this is my first winter with my HHR.
As for CHAINS------you can NOT put chains on an HHR? Chains are often required by law enforcement on the passes!
And-does this include/mean the small cable chains? I sure hope they will work-they make your car into a tank in bad conditions!
I appreciate any replies to this issue!
SP
From reading more-I understand that the reason for the chains not working is from the strut/business side of the tires.
Would these thule chains work? Again-I want to reiterate that occasionally on mountain passes the state patrol REQUIRES chains-and is more than happy to pull everyone over without them.
Here is a link to the thules...they only mount to the outside of your tire-
http://www.autoanything.com/driving-...A4339A0A0.aspx
and i have to admit that the stock firestone runs very well in the heavy snow, sure winter tires are the best i couldn't denied that but i was really amazed with my stock tires.
