Solstice Rims on my LS
Old Mar 11, 2022 | 09:22 AM
KArthur's Avatar
I finally got my new tires and rims on the HHR. I did replace my struts with new KYB struts. Not using any spacers or longer studs..... but it is a very close fit around the strut area. The tires does not rub anywhere, even when turning full left or right. The tires I mounted are 225/45/18. I might go back and add spacers and longer studs (if I can find some that will work).
Old Mar 11, 2022 | 09:10 PM
Close like this ? My '08 Panel 2LT has this tight clearance on 26.1" tires. I run 225/ 50 / 17" tires.
Old Mar 11, 2022 | 09:32 PM
225/45/18 is the same size that the HHR SS came with. Memory says that size specs to 25.97 inches.
Should be just fine. Although the ride quality may be a little stiffer now.
Old Mar 12, 2022 | 09:49 AM
PulpFriction's Avatar
HHR wheels are 42mm offset (mostly. I think I remember one at 41mm.) The Solstice rims are nominally 55mm offset, so close to what you measured. That’s more than a 1/2” difference. I recall owners saying a .25” spacer works without modification to the lug bolts and works for the Solstice wheel, presumably without an excessively wide tire. While that still narrows the track of the car by slightly more than 1/2”, it’s better than over an inch without the spacers.
Old Mar 12, 2022 | 09:08 PM
Old Mar 12, 2022 | 09:21 PM
KArthur's Avatar
Yes. Exactly. Probably less clearance on the inside between the vertical portion of the strut and the tire.
Old Mar 12, 2022 | 09:34 PM
Wow, keep an eye on inside of the tires, hard cornering could cause a slight rub that close on vertical
SkullWerkz
Tires & Wheels
Jul 25, 2021 06:21 PM
Dek
Tires & Wheels
14
Mar 6, 2020 09:11 PM
Sirjenx
Tires & Wheels
10
Aug 14, 2009 11:45 AM
220
7
Apr 11, 2009 09:42 AM
hhrcrafty
18
Sep 2, 2007 09:52 PM
