Solstice wheels fit!!??
Old Aug 24, 2008 | 10:36 PM
orange08's Avatar
Red face Solstice wheels fit!!??
I took my wheel and tire off of the pass. front of my HHR and put just the Solstice wheel on the hub assembly. It worked fine! It did not rub any where!
I jack the driver side up also and spun the stock tire and wheel to see if there was a problem. It spun freely. But It was just the wheel no tire. I can see that it is going to be a close fit, but I want to try a 225 45 18 on it. Anyone new seen it done?
Old Aug 24, 2008 | 10:53 PM
WaGoN MOnger's Avatar
the stock tire size on a solstice is a 245 45 18 i think...
Old Aug 27, 2008 | 11:15 PM
orange08's Avatar
Exclamation
I saw the pic the Red HHR with the Solstice wheels on it and it looks like the factory Sol. tires 245 45 18 = 26.72" 9.68" wide. Dang!!! Moster truck HHR.
He did not need spacers He needed a lift kit!
Old Aug 30, 2008 | 11:00 PM
orange08's Avatar
I went down to my local Discount Tire Co. and tried on a 225 45 18 on the wheel and it worked. No rubbing!!! They ordered the other tires and will be in in a few days.
Old Mar 12, 2009 | 06:58 PM
birdflames's Avatar
i know its an old post but any updats on the wheels? im looking at getting some for mine, and everyone is saying different things, with spacers or not, and with the offsets being dif. or not... any info would be greatly appreciated.
Old Mar 12, 2009 | 08:12 PM
ballplr's Avatar
I just got a set. I have 235/40/18 tires on my wheels. I put one on the driver front and it was rubbing the strut. If you use a thinner tire you may not have any problems, but the offset's are much different. Solstice 55 HHR I think 45. I am going to use spacers on mine which means I will be installing longer wheel studs. Just waiting for the bad weather to stop before putting them on.
Old Mar 12, 2009 | 09:31 PM
birdflames's Avatar
Thanks, ill have to find out tom. about the tires, bc i found a set locally for 300 with tires, and a little rash, thanks for the info, and if all goes well hopefully i can get them and maybe do the powdercoating like the ss wheels were. any suggestions on where to get the spacers, and studs, and or prices?
Old Mar 13, 2009 | 06:05 AM
solman98's Avatar
Several have put those on here and they all had to run spacers while using a 225 tire. offset just requires it since it's a RWD wheel.
But they do look good.....
Old Mar 20, 2009 | 07:54 PM
DANSHHR's Avatar
i don't know about wheel spacers..i heard nothing good about them... worn out bearings, uneven tire wear, get cracked/broken, and sometimes vibration.
Old Mar 20, 2009 | 08:51 PM
Don Juan's Avatar
pics of installs would be much appriciated.
